BBC Header Options
lasttime78
465
D313's Generic or not (7 Malibu's later and still fit the best with a big block) also they still look great with the ceramic coating. Good ain't cheap, and cheap ain't good !
bww92ls1
76
Smiths Grove, KY
Tommy,
I am the op and apologize, but I was confused. Doug's website listed the d318 as the BBC part number and the Jegs I am looking at list the d330 as the BBC part number!
bww92ls1 said:
Tommy,
#-o Duh. I didn't even notice it was you...
bww92ls1 said:
Please respond lastime78! Also.... What size primaries should I run with a 30 over 427 12:1 580 solid lift 990 heads 950 carb?
2241's are fine for that. I'm gonna use them on a fully ported 188 headed, 650 solid roller 10:1 454...
bww92ls1
76
Smiths Grove, KY
-Just have to say that the Hooker 2241's and the Doug's D318's look identical! For the price I would have to go with Doug's headers. I would assume they are made the with the same material.
-If the 3/4" primaries are sufficient then I may opt for the d313's, but are they big enough?
-If I go with the 2241's then exactly what modifications need to be done. I am using the stock style small block mounts with new polyurethane inserts.
-lasttime78..... You have yet to reply! I will P.M. you
Thanks!
lasttime78
465
Wow, forgot about this post. The Doug's headers are tuned! to those who believe they are not. You are wrong used for many years and have had others order. As far as mods trim both stock clam shell motor mounts and taking off 3/4 of inch on lower rear a-arm on passenger side. For the money and the looks of a clean engine compartmant thats were I would put my Money. Sorry took so long to respond.
