BEST BOLT IN 9IN REAREND???
COPO 572
1,325
Morrisville, NC 27560
Complete Strange unit with the big Ford ends and brakes. Detroit Locker and 35 spline axles. I like it, but don't have anything to compare it to except the 7.5 that use to rest in it's place. Compared to that.........very burly.
abigda
616
Springfield, MA
LS6 Tommy said:
Robert1320 said:
You'll need adjustable uppers if you go with the 9".
??? Mine was a direct bolt-in with stock suspension.
X2, same here Tommy
JBreu
321
Livonia. New York
Currie has a decent rear end as well..........These are all aftermarket rear ends. There is no "True" bolt in 9" rear out there for our cars...Why not keep your GM car all GM and grab a 12 bolt rear from a '66-'72 A body Chevy car.That's the closest to a ""true" bolt in out there.BTW, I'd put a 12 bolt up against a 9" any day :D
abigda
616
Springfield, MA
I was going to do the same, until I figured out it required buying new rims with more backspacing. This was about 6 months after I had bought new torque thrust 2's
SSedan64
948
MACON, GA.
Yes, If you already have Rims it makes a difference.
Rear Widths:
G-body= 58"
65-67 A-body= 60.50"
68-72 A-body= 62.50"
83LSWagon
592
Spring Hill, FL
And the 9 is a poor mans quick change.
cbh-7726-80
117
maple ridge,b.c.
i have alston fabricated housing and trailing arms,strange centre and axles,full 3 inch tail pipe exhaust,all fits together nicely,ford 11 inch rear brakes with welds and m.thompsons,fits tight but all clears,
big gear head
44
Central City, KY
Moser makes a bolt in 9 inch and a bolt in 12 bolt for the G body. I like the Moser housing ends better than Strange and some of the others. The Moser ends will allow you to use a stock Ford axle seal, where many of the others rely on that O ring on the outside of the bearing to keep the oil in.
Bar50
1,877
Tulsa, OK
The 12 bolt in not in production or has not been in the last two years when I called to buy one. Maybe now, but, I doubt it, same with the Dana 60 to fit a G-body. Oh, and they were only about $1200 for the housing.
JuniorJ
http://www.speedwaymotors.com/Winters-Grand-National-Rear-End-GM-Metric-Brackets,4856.html
Winters floater Grand National style rear end features lite weight steel hubs with brake rotor mounts. Rear end comes complete with a new housing, two hubs, two brake rotors, two solid 31 spline axles, two drive flanges, ten lug nuts, rotor and drive flange bolts along with all the needed bearings and seals.
Now available in either a 5 x 5" or 5 x 4-3/4" bolt pattern and three different widths:
•58" centered
•60" centered
•62" with a 1/2" offset.
All that ^^^^ for $995.99
Know of 6 people that are using them without any trouble, and most of them have had them for 3+ years now.
