big block problems sweden!
sweden
25
hii, hope you understand my English, i have just finish a Engine swap in my Malibu-79 , the new Engine is a 454-73, i tryed to started it today, but it moves very Heavy, i have new battery and a nearly new starter, but its not enough, the battery is empty in a few seconds...can someone give me some help?
melloelky
3,654
31
mass
maybe your timing is to advanced?try turning it your distributor counterclockwise then see if it does the same thing.if you can keep a charger on while your trying to start the engine too.
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
turn the distributor clockwise to retard the timing. Also check that you have a good ground from your block to your battery.
brian
sweden
25
I TRYED TO TURN THE DISTUBIUTOR AND THEN ITS GET BETTER, BUT AFTER A FEW SECONDS THE STARTER MOVE OUT OF POSITION SOME MILIMETERS AND THEN THE STARTER JUST SCREAM, WHATS WRONG?????
