big block
84355SS
62
southwestern michigan
Right now I am changing from small block to big block. So far I bought .060 over 454 , 496 stroker crank, and 6.385 rod. I also bought 781 oval-port head. I have not bought the pistons yet because there are couple options with compression and not sure what 781 heads CC's , valve size. So far I think it is 113cc with 2.06/1.72 . Is that right? I am not doing the engine by myself, but my local shop is doing this for me. I just want to learn more about it and head into the right direction. My plan is to make 50% street and 50% strip. Also which flat tabbet hyd. cam would be best for me. Any advice would be great. Thanks.
454mali
1,393
Cleveland OH
i'm pretty sure the 781 heads are more around 120cc
im running a big block, went with eagle steel crank, eagle forged 6.385 rods, and srp flat top pistons makes around 8.0-8.5:1 compression with the right head gaskets and 119cc patriot aluminum heads.
they are a good head but are 119cc-122cc arent they? what kind of compression are you looking for just 10.5:1 or so? for street manners i went with low compression due to the 871 blower thats sitting on top haha.
454BBCMalibu
117
MONTEZUMA KS
i have 9:8 to 1 one on my 454 and it runs fine on pump gas you could probeby go a little higher to and its got a 272 crane cam .515 lift its pretty miled im changing to a bigger one soon it lopes pretty good until you hook the transmission up
84355SS
62
Yes I am looking for street manner with good number at track. Will the flat top piston be good for street or can I go for the dome pistons. This will be with 781 heads. Sorry for more questions, I am really excited and my first big block. :D
GreenDragginBu
6,293
N.E. Ohio
SRP Piston 212157 will bring you right close to 10.1 with 120cc chambers. small dome.
Jayz81ss
115
Ontario, Canada
My 461 runs great on pump gas 9.7:1.
I ran the the 781's with flat tops and an edelbrock performer rpm intake and cam .560 / .573 worked great on the street and put the monte into the low 12's.
The 781's are 113cc 2.06 and 1.72. They are a good head, but with the 496 stroker you might consider putting 2.19 valves in them.
Phantom
1,709
DeSoto Wi
781's are 118cc
I know a 2465f trw pistion and those heads will run on pump and their .270 pop up
