big radials under a monte
STROKER
398
SOUTH FLORIDA
can anyone tell me is a 15x10 wheel with a 3.5 bs & a 325/50r15 et drag radial fit under an 84 monte with a 8.5 with c clip eliminators .. no frame notch but rolled fender lip... the c clip elim. move the axel out 3/8 of an inch after cutting the ends of the axel tube...I think i will have plenty of room by the frame but i dont want the tires to stick out past the fender.. i appreciate the help... 8)
Supe
15,116
Charlotte, NC
No way. That is a HUGE tire, and will never fit without a frame notch, deeper backspacing, and work to the wheel wells.
MISFITmalibu63
7,163
The Sticks... Tewksbury MA
540malibu has a 325 under his car, but also a mini tub, frame notch and the lip is rolled.
540Malibu
1,432
Shrews., MA
yup, requires a full frame notch (1.5") minitub, and 5.5" backspacing with a rolled lip, and depending on the frame a 1/4 inch spacer. i also have airbags to keep the squat to a minimum.
ill post some pics as soon as my camera equipment gets delivered
4doorbu
1,877
south jersey
if people fit 295's MT's on them, then 325's will fit
4doorbu
1,877
south jersey
and the 295's are 2" taller.
10secBu
4,284
Westminster, MD
Well, I can tell you I had BFG 325's on a 9.5" rim and they measured 13" section width and fit with a 1" deep notch.
I have 295/65 M/T's that measure 12.75" section width on the same 9.5" rim. They also fit nicely width wise.
My car swallowed the 275/60 M/T's.
