Well I swapped out the Wilwood Master cylinder that I suspected was bad with a new one. Went in fine. Bled the brakes OK. I now have brakes!
Now the bad news, (you didn't expect it to go perfect did you?)... I'm not happy with the performance. I couldn't lock up the brakes no matter how hard I tried, I didn't even feel safe enough to take it out of the neighborhood. It does stop, but expected performance at least in the ballpark of the stock power MC I removed. I moved the push rod up to the stock manual hole like some have mentioned on the forum, a little better but still not going to cut it.
So...is this what you get with the wilwood MC and an otherwise stock brake system? Or is there stll something not right? I have asked several times, but haven't gotten a definitive answer, should I still be using the stock combo valve? Something else?
Oh, finally, I learned not to fling open a cowl hood on a very windy day. So now I can add a new windshield to the list of things left to do to finish the car. All in all, the day was one huge kick in the b@lls.
