Help me. I have a new master cylinder, new soft lines, new proportioning valve, and new wheel cylinders. The brak system is totally stock GM front disc and stock rear 9" drum. i put speed bleeders in all four corners. i have bench bled the master cylinder.
I crack one speed bleeder and pump the pedal. i get fluid out the front calipers, but nothing out the rear wheel cylinders.
I removed the right rear speed bleeder completely hoping fluid would find its way with gravity, but after a half hour or so of waiting, nothing. I put the speed bleeder back in and pumped the pedal for a good 50, 60 times. Nothing out the right rear brake wheel cylinder.
The fronts are working, i can hear the pads moving and squeaking. I just can't get the rears to start bleeding.
What is my next step to get the rears bled?
I found a $37.00 white vaccum plastic hand held pump at the local parts store and the guy behind the counter said that was the only tool he knew of that might work for my situation. He also said he never sold one and never used one, so i am skeptical.
Please help! I want this wagon back on the road and it's so frustrating because I know the master cylinder is good and the parts are all matched. What do i need to do to get the rear brakes bled?
