Buick V6 TBI conversion
1982 SS
382
Clearfield, Utah
First off, has anybody converted the buick v6 to use a TBI like the 4.3 v6?
My carb is starting to fail and I've been looking to get my feet wet with a Megasquirt for a while now. I'm sure i can make any of the 4.3 sensors work and i can use practically any distributor i want to control the spark. The only problem i can see is the lack of adapter to go from the rochester 2 bbl to the tbi. Transdapt makes a 2 bbl holley to tbi adapter, and i need to know if the Rochester 2 bbl and the holley 2 bbl share the same bolt pattern. If they do I think this can be a doable option without spending too much.
Does the holley 2bbl and the Rochester 2bbl share the same bolt pattern?
1982 SS
382
Clearfield, Utah
Look at the EBL too. It's basically a plug & play setup that you tune via laptop from the driver seat. I'm running a 383 capable of 370-400hp with it, liquidh8 has used it as well. Personally I think it's the bee's knees far as TBI is concerned, and Bob is great with tech support. He should be able to give you the best solution for your setup.
80ECLT
3,927
Sheboygan Falls, Wisconsin
You could have one machined, it would be a simple part. Most job shops would probably charge you less than 100$ for it
