bump steer kit
malibu43
116
hi, there,i just got my bump steer kit from speedway,but i need some info about the procedures and how to install it,i got the clues from searching in the net,but i want to make sure all the steps,will be great if you can post some pics,if is not please try to use a plain english to get myself clear and do it right.
remember its a 80 malibu for road course racing
regards
Well, I can't give much install help, but you need to get ALL your alignment adjustments done BEFORE you adjust the bumpsteer. Unfortunately, if you've got B-body spindles, the kit won't help. You need to lower the inner link or raise the outer link for them the kits that are currently on the market don't give enough adjustment on the inners or they only allow you to lower the outers...
malibu43
116
Thanks Tommy,but anything will be better then nothing,i mean,if the speedway kit only alow me to fix the outher links will be better then nothing right?
regards
am so for from the states,and in my first intend to do something right to my car the parts are not right,bad luck.
