c-clip eliminators
grizwald
3,300
Ontario, Canada
http://www.summitracing.com/search/Department/Drivetrain/Section/Differential-Rear-End-Components/Part-Type/C-Clip-Eliminator-Kits/Axle-Model/GM-8-5-in/?Ns=Rank%7cAsc
LSJM1
134
Atlanta
I was not aware you could bolt on c-clip eliminators and use the stock axles.So the bearings are pressed on to the stock axles?
z28krazy
150
New Braunfels, Texas
Yes...they come with press-on bearings. Note that you can also buy a pair of c-clip eliminator bearings separate from the kit, as in: replace axle bearing time.
