Car is dead
I used a sidepost adapter that you use for car amps, it threads in like a battery cable stud, then a bolt threqds into that.
unclepudge
348
CT
After much wiring part of the problem was the battery had 13 volts when I 1sthave checked it then after replacing both fusible links and removing what appeared to be a fusible link on the pink wire I still had nothing checked battery which was on trickle for days it only had it 8 volts. Dead cell. Now to finish wiring plug wires and a few small odds n ends.
