2x4 wood car stands
DOUG213XRJ
4,661
West, MI
I see them on a lot of TV shows. Has any one built and used these ? how safe are they for a complete car ?
Thanks Doug
Killerdave8813
885
Cincinnati,Ohio
Huh, never heard tell of such a thing, I'd like to see some pictures of that, I've seen pics on here of guys using timbers and concrete blocks to hold body shells for frame offs but never seen anything like that, I think I'd prefer steel, besides you can get some pretty good jack stands these days pretty inexpensively
Toner283
291
Arthur, Ontario, Canada
Google image search wooden car stands or wooden car cribbing. Lots of photos on the net. The biggest advantage of having a car up on the wooden cribbing is you can work at it with everything at ride height. Depending on what job you're doing this can be very helpful. As long as they are built correctly they are just as safe as jack stands and probably from an engineering standpoint, stronger. They can be built as high as you need them for whatever job you're doing, the only limitation is how far your jack can lift the car. Not really practical for an oil change or a short-term repair but something that's going to take a few days or weeks to accomplish they are an excellent option.
Screwloose
1,785
Minneapolis, MN
The more common name for these are cribbing.
7 Wood steering wheel Interior Tech 3
M My old car General Discussion 1
Dr.Exhaust Street to strip. Looking to build a mid-9 sec street car on 10.5 inch tires. Introduce Yourself! 11
R new ground up rewire bracket car Electrical/Wiring Technical 7
UMI Sales UMI Green Machine @ Ohio Muscle Car Challenge Suspension Technical 4
M 1980 malibu first time drag car setup Suspension Technical 7
_Stylez Car bogs down Drivetrain Technical 7
grizwald trans cooler on a drag ONLY car? Transmission Technical 7
D What is this car worth???'s Drivetrain Technical 3
Wagonized What body mods would you do to your car (if any)? Autobody/Paint Technical 22
B street car bottle mounting Power Adders 3
45CHI CAR IDLES GOOD, BUT WONT DRIVE FORWARD LSx Tech 3
S malibu 369 car to efi questions please help!! EFI Tech 5
S Do you think 7" of droop/travel is enough 4 a low hp car? Suspension Technical 2
S car hieght after 8.8 swap Drivetrain Technical 5
Darwinskeeper Racing Wheels and the Street Driven Car Wheels/Tires/Brakes Technical 1
81classic Now the fun begins - rewired car Electrical/Wiring Technical 5
ElCamMan515 Moroso Trick Springs Prt #47135 On Street Car? Suspension Technical 4
unclepudge Car is dead Electrical/Wiring Technical 11
U car rotissiere Autobody/Paint Technical 0
M Race car wiring diagrams? Electrical/Wiring Technical 4
C Car won't start, need help troubleshooting! Drivetrain Technical 7
T Basic upgrade towards a slot car (79 malibu) Suspension Technical 14
X Exhaust on factory stick car Drivetrain Technical 9
JRodS79 i robbed a grandma for her car V6 Tech 3
R Good car cover ? Autobody/Paint Technical 0
G car breaks up at 3 grand then dies Drivetrain Technical 5
81Malibu-4DR Painting the car, tips? Autobody/Paint Technical 17
81Malibu-4DR Paint the car, tips please?!? Autobody/Paint Technical 8
S Tach wire for V6 car Electrical/Wiring Technical 0
malibu7800 Has anyone tried setting up there car for E85 fuel? Alcohol/Ethanol 8
madmaxx57 how can i tell if my car originally came with a v-8? Drivetrain Technical 3
9secmalibu finally found the right tire for the car! Wheels/Tires/Brakes Technical 3
R Car Alarm system ? Electrical/Wiring Technical 1
prostreet66 hows the car coming? MalibuRacing Father/Son Project 5
L th 350 car dont move in 1st gear Transmission Technical 1
D Car audio wholesale... Electrical/Wiring Technical 10
sevent1nomad 267, why because thats what is in the car Drivetrain Technical 7
H simple race car panel Electrical/Wiring Technical 1
H car not turning over & remote solonoid Electrical/Wiring Technical 6
M Drag car wiring has been gutted Electrical/Wiring Technical 9
7 MOOG springs for a big block street car? Suspension Technical 4
W race car wiring... Electrical/Wiring Technical 4
S Post a picture of your car with a ls motor LSx Tech 56
C Drop Spindles In A Drag Car Suspension Technical 14
S Is it a G-body thing or is it my car? (rear not centered)??? Suspension Technical 8
E roll your car??? Autobody/Paint Technical 10
79sbcmalibu need my car to hook any suggestions Suspension Technical 5
C Need Help on New car Suspension Technical 1
B front brakes for drag car Wheels/Tires/Brakes Technical 4
Similar threads
