I have stock brakes up front and LS1 FBody discs in the rear,i had crappy pedal response with the disc/drum proportioning valve so i replaced it with a disc/disc valve from performanceonline,now the pedal is stiff with no action and the brakes locked the first time i pumped them,car is the 87 in the sig and has stock master cylinder and stock power booster.i will try to bleed the brakes and bench bleed the master,will this help?
