59RAT said:I wouldn't go over 9.5/1, but I think 8.4-9.0/1 would be the best range, when you go to high on the comp. you limit the tune up. You can, with lower comp. add more boost to make up any short falls if needed. On my Impala I run 8.0/1 with around 1100rwhp with 25lbs. boost only on E85 fuel. Before I used 93 oct. pump gas and 911rwhp. couldn't use as much boost or timing. The fuel does play a big part of the tune also. Hope this helps. Rod
MEGABU said:59RAT said:I wouldn't go over 9.5/1, but I think 8.4-9.0/1 would be the best range, when you go to high on the comp. you limit the tune up. You can, with lower comp. add more boost to make up any short falls if needed. On my Impala I run 8.0/1 with around 1100rwhp with 25lbs. boost only on E85 fuel. Before I used 93 oct. pump gas and 911rwhp. couldn't use as much boost or timing. The fuel does play a big part of the tune also. Hope this helps. Rod
good call. i'll be running a single turbo with about 8.5:1 squeeze, and i'll run 94 octane on the street with the boost limited to around 15 psi, and at the track, i'll dump in few gallons of 110 & crank the boost to 22-26 psi, & see what it'll do! i'm switching to aluminum heads, too, so i'll have a little more room to keep it out of detonation.
Robert1320 said:For the 355 I would look at an S400 (75mm) B/W we sell they for about $600.00.
lol...tryin' to keep it cheap! otherwise i would follow your advice to the letter! :lol:basketcase said:1) Big Procharger
2) Lots of Compression
3) As much Alcohol as you can pump through 24 160lb/hr injectors.
All you need
