Computer Size??
rumblbu
162
Muskegon,MI
Can anyone tell me what size the stock 2005ish truck computer is? I am also wondering if anyone knows if it will fit behind the passenger side kick panel from a computerized g body?
Thanks, Rick
blubaldmontess
872
Clarksville, TN
I've looked at the computer, and should it fit, yes, but I haven't actually tried it. I've got a 2003 truck computer, but the cars put away for the winter, in the spring if you remind me, I'll try it then :D
83LSWagon
592
Spring Hill, FL
I put the computer from a camaro in my wagon. Had to do some chopping, cutting, and gluing, but it does fit. This isnt the final product, but I'm tryin to figure out my next move.
rumblbu
162
Muskegon,MI
So it fits...kinda? I can work with that, which way are your connectors....up or to the front of the car?
rumblbu
162
Muskegon,MI
Doober said:
There is a bulkhead below the HVAC box where the factory wiring passes through. You may be able to go that route, but the hole may have to be opened up to fit all the wiring for an LS engine through.
My car does not have the hole in it but I grabbed the grommet and the steel grommet retainer from the junk yard last weekend, I am with you on the hole being too small.....it will need some massaging. :D
83LSWagon
592
Spring Hill, FL
To the front.
4,757
I always assumed the LT and LS computers were in the engine bay for better cooling. If so, wouldn't it be a problem putting it behind the kick panel where it may get too hot?
79loserbluebu
302
Illinois-60491
I disagree. On V8 TB's it's mounted 2 inches from the d/s manifold. I think it's mounted in the engine bay just to save the company some money on the wires and wire protectors and grommets
