control arms
dasbrdr
411
Seattle, Wa
You could grind the teeth off the washers and the one side of the bushing insert. I did this as cheap alt and it really frees up a lot of movement. Also lube the ends of the rubber really good before installing.
grizwald
3,300
Ontario, Canada
thanks...if i decide to stick with the stock ones, i'll definitly think about doing that.
has anyone ever used these?
http://www.summitracing.com/parts/AFC-20069/
seems like a pretty cheap alternative to the del-a-lum ones. also, if i do the lowers now, do i HAVE to do the uppers as well?
