hicksport said:
Im looking for input from everyone here!
These are my plans so far Tubular upper and lower front a arms from spohn, tall spindle conversion and brakes from kore3. Not sure on the spring shock package yet. Looking at air ride.....Sway bar as large as I can find..Anyone know who sells herb adams stuff any more??
Rear Adustable upper and lowers sway bar and air bags for sure.
Want this thing to handle as good as my 2000 ss camaro did.
Thanks
Collier
Talk with Spohn techs about your ideas. Unless you have the engineering aptitude, listen to what they have to say. Or any other after market company which has done the R&D on their suspension parts. Once you start mixing parts you could get yourself less than desirable results. Ending up with some good looking paper weights. Also you could try GW, Hotchkis & SC&C for handling ideas for the G body (lots of goodies available).
Don't use poly bushings in the control arms, they will bind.
Try and match your springs and shocks. Or get adjustable shocks, Koni, QA1's etc...
One thing to remember about sway bars is that they are a tuning aid.
There are 2 thoughts on this matter.
1 soft springs and large diameter bars.
2 heavier springs with thinner sway bars.
As the sway bars in conjunction with the springs can overwhelm the shocks. Causing a poor ride and handling.
The limits of the G body platform lay in the rear triangulated 4 link in my opinion. Very good design for drag racing with minimal upgrades. But fall short for handling purposes. Yes can be made to handle on smooth pavement but we don't live in a pothole free world.
So far personally pulled .90 G's in my Bu. That was a steady state corner btw. Still trying to figure out how to make the car better in slaloms.
Last thing to remember, if the frame/body flexes the suspension will not work as desired.
And your car will only be as good as the rubber touching the pavement.
Jerry
