... another little project I was thinking of doing. At first I'd thought of using the trailer-style waterproof LEDs you get at most trailer supply stores/Autozone/etc...
Then I started looking into LEDs and LED strips, turns out they make waterproof versions, but they're a little pricey. I'm thinking of finding some broken '81 taillights (or '78s) and using the housings. The plan would be to mount them behind smoked plexiglas, and the light pattern would be similar to the Regals/GNs, with an amber strip in between the two red strips... I'm still in the thinking stage because I'd need a slightly dimmer strip for the running light portion though. It's likely the reverse light housing/lens would stay since it's clear, and I could just get a plug-in LED bulb for that.
