Double adj shocks with stock a arms
cherp22
2,777
Roxana, IL
I read on trz's website that you may have to modify the front a arms to put these on. Just took my old shock out and the new shocks definitely won't fit in the opening. I assume everyone opened up the hole for the shock and drilled new holes for the hardware? Who is running these shocks with stock a arms? Any pics? Advice?
cherp22
2,777
Roxana, IL
I had to use a plasma cutter and open up the hole for the bigger shock to fit through it. I am running strange doubles.
gman415
883
Chattanooga
Ok,Thanks. I have QA1s myself and had never heard of this but shouldn't be a problem.
cherp22
2,777
Roxana, IL
I think the strange's are wider than the qa1's. I know the qa1 knobs are right next to each other and the strange are opposite sides which makes it wider. You might not have to cut with the qa1's but I know I did with the strange.
