drive shaft length
442force
27
Middletown Nj
let me know what you think i have a chevy 355, th350 and the stock 8.5 10 bolt and im pretty sure the stock drive shaft from the cutlass the 200r4 to 8.5 shaft wont work
do i need a drive shaft out of a monte ss? with a th350 and a 7.5? or is custom the only option?
both the 200r4 and the th350 are same length,the stock driveshaft from the cutty with an 8.5 rear will work. just get it balance checked for good measure before you put it in. the driveshafts from cars with 7.5 rears are 1 inch longer.
442force
27
Middletown Nj
its a short tail th350 outta a car. or el camino vice versa.
so itll work? hopefully im dropping the motor and trans in this week when the rain stops. so either or ill know.
442force
27
Middletown Nj
how are you guys cutting these shafts? like crude sawsall and welding it back? or of the yoke to the trans. im a g body newb trying to play with what i have.
