I have been looking through the site, and havent found much talk about this, so I figured I would put it out there. I am going to be building a drag car, and I will be going with a small block setup. I know a lot of the cosmetic differences pre 87 and older blocks, and the post 87 blocks, but with the post blocks, you have the option on the vortec heads, which I know can bolt onto the older blocks, as well as a lot of the post blocks are roller blocks, etc etc. But my question is, from more of a money stand point, would it be better to go with a post 87 block to build up for some easy horses? Generally, you can go to a junkyard and find a vortec engine pretty easily, but then again the older blocks arent THAT hard to come by... I was thinking I would go with a 355, maybe a 360 ci engine. All I have to do is hit 10.90 in the 1/4, but wouldnt mind being able to run a 10.60 or so, just to know I can adjust the engine for altitude adjustments and such. I plan on running a 5.14 rear gear, so I know I will be able to turn the rear tires with something that deep, and push it with a 3 spd such as a T350 or T400. Any pros/cons/guidance?
