FRONT COIL SPRING & LOWERING QUESTION
MYMONTECARLO
50
CINCINNATI,OHIO
Hey,guys. I'm lowering my car, I have moroso front trick springs, I just cut 1 coil off,dropped car like 2" . On the driver side the rubber isolator fell out and I installed spring without it, ARE you guys running this rubber isolator with your trick springs? What would be the pro's & cons of not running it,now car sits uneven in front so I either have to install on driver side or take out passenger side,that piece is about 1/4" thick ,so that's about what i need to even out front...
LuVnThE1320
15
from prior expierence the only thing i noticed was witout the isolator i had a lil more road noise like a ting when i hit a bump from the suspension traveling up and down.
