Fusible link
Wile E
1,075
Central WISC
The harness I'm using came out of a parts car and the terminals have been cut were they attach to the solenoid, so as long as I have to attach some new terminals , I thought replacing the fusible links at the same time might be a good idea since I have the harness on the work bench. Question is...Am I better off wiring in fuses or breakers vs the fusible links?
ScotSea
381
The idea of a fusible link is a safety feature of the last resort. It is not intended to ever be used in normal operation. A fuse is not really meant for that location. Dirt, oil & water can all get in the fuse holder, causing you a problem at probably just the wrong time. If you want to replace them, go ahead and use new fusible link material.
Wile E
1,075
Central WISC
What amp? 30?...Where do I find the amp rating?
ScotSea
381
This will give you some information:
http://www.madelectrical.com/catalog/fusible-link.shtml
http://www.whiteproducts.com/fusible-faqs.shtml
http://www.whiteproducts.com/fusible-specs.shtml
Wile E
1,075
Central WISC
Ok, so it does not really go by amps but gauge of wire...and parallel connectors, that's new to me.
Excellent, Thanks ScotSea.
