Separating pitman arm from center link
The Roudy #3 4 ever
227
plummer idaho
Bought a manual box from a member here that has the correct pitman arm already installed. Doing the jeep shaft conversion at the same time. Best way to separate these w/o tearing things up too bad? Just replaced all front suspension components 2 seasons ago. If I use a fork and a BFH it looks like I'll tear things up.
Ed Cannon
1,682
Johnson City Tn
A fork is the only way I know of.
The Roudy #3 4 ever
227
plummer idaho
Well, here is what worked for me and I didn't tear anything up. Removed the 2 bottom bolts and left the top one loose on the box. Used my aluminum Harbor Freight jack to put tension on the pitman arm. Instead of using a torch I utilized my heat gun set on low to heat the pitman arm. After 10-12 minutes it got hotter than I thought it would. With pressure still on from the jack I used a big punch and my 4 # engineers hammer, one good tap and success. Didn't hurt the boot on the center link.
malicad
1,383
South Milwaukee, WI
^^^Agreed. Pickle fork attachment on an air hammer, and if the boot tears, Energy Suspension makes poly ones for cheap.
