79malibusbc said:
in mean78's case i would just run the control arms in the factory hole. with the car being lowered the IC is shorter already and if he leavers the lowers with the brackets its very short and likely see tire smoke on a sprayed launch
Whith the instant center closer to the rear diff it just puts more of the weight transfer onto the tires. I've seen guys running low 10's, high 9's with SSM Lift Bars in their cars. they never complain of a loss of traction. If it hits the tires too hard then unloads, maybe those guys are running the wrong air pressure in the slicks. Everything has to be tuned to work together, including air pressure. you can't take a car that runs one way, just bolt a set of lift bars on it and expect it to react better then it did before, thats why they have "test and tune" at the track. Also, no one is mentioning pinion angle in any of this, which if you are lowered or not has to be set correctly.
