having motor mount issuse.
littlefranks
543
pembrokepines FLORIDA
so i got a set of edelbrock ls conversion mounts solid morosso mounts,got it together and the frame pads dont line up with the origanal holes,looks like im welding them on the frame.
I am almost positive that those frame mounts only use 3 of the bolts, is this your problem? If so 3 bolts will suffice in this situation. No worries.
blumonte
83
minnesota
Funny you should post this. I had the same problem setting mine in last night. I have transadapt plates and stock mounts though. And I have moved the frame mounts back a hole but after a half an hour with the pry bar and some beer I made it work. :lol:
rjleiker
261
Derby, KS
My stock SBC clamshell mounts only use 3 holes. I have seen others doing the LSX swap where they had to move the mounts back one bolt hole with similar mounts.
the moroso solid motor mounts only use 3 bolt holes, you should not have a problem.
littlefranks
543
for some ungodly reason the top bolt holes on both sides wont line up.three bolts will only be used im notching the cross member anyway so ill just weld the frame pads in place.
Are those the short tab mounts? They have 2 different lengths, looks like you may have the longer one's in the pics. Probably causing the motor to sit higher w/ the taller mounts.
rjleiker
261
Derby, KS
Maybe they are upside down... or on the wrong side... just a thought... it happens...
not sure how they're set up, but you might check it out...
