header fitment question
slimbo
4,223
www.yellowbullet.com
getting new headers this winter and i really like the dynatechs but they dont make them for our application. they do make them for for 70-81 camamro and 68-72 chevelle with sbc. i thought i read somehwere that one of those apps will fit our cars as well. anybody tried it? they are about 300 less than the hedmans i was lookig at so i was wondeing if they are gonna fit.
BrianH323
366
NJ
I put 1 7/8 Schoenfelds on my car, just got everything bolted in yesterday. They fit great. Let me know if you want pics or you'll probably see it in person sometime.
Brian
slimbo
4,223
are the 1 7/8 scho's a standard bolt pattern? they clear the lower arm mounts? you running angle plugs? the cost is a big factor for the scho's they are like 500 cheaper the the huslers.
BrianH323
366
NJ
Yes standard pattern. Yes angle plugs. Really close to the pass side lower mount, I can probably slide a pice of paper in between. Can fix with a BFH, but too late now.
The paint rubs off when you touch them, so either repaint with something good or get them coated, which I did.
I'd buy them again in a heartbeat.
Brian
malibuwgn80
259
Scappoose, OR
s23.photobucket.com
Dyna tech makes them. I have there 1-5/8 to 1-3/4 stepped header on my car. The fit is very good. I also have a set 1-3/4 to 1-7/8 stepped Schoenfelds that i had in the car befor. The fit is ok. Dynatech only makes up to 1-3/4 primary tube size.
http://www.afabcorp.com/AFCO_Dynatech_USbrake/merchant.mvc?Screen=CTGY&Store_Code=Dynatech&Category_Code=metric
slimbo
4,223
Brian
lets see a pic of those brian, they fit good? who did your coating and how much?
BrianH323
366
NJ
http://s82.photobucket.com/albums/j278/BrianH323/Headers/
Coating was $220 by QC Coatings in Michigan. http://www.qccoatings.com
Brian
sheldonw
62
i have the shoenfeld stepped headers. they're tight by the starter and control arm mount but nothing major
