help
RatDime
575
Ind
Hey guys I have a problem with my engine, the only thing I did was replace the water pump and the cyl heads-I went to alum with bigger valves and runners, anyway, the engine free revs great, but under the load it will not go past 3500 rpms then it backfires, spits, and coughs out the exhuast only. What sign is this giving me? I re-ran the valves, timing, checked the plugs and its burning great, fuel pressure does not drop. I bought the heads used-very low miles, and they have duel spring setup instead of my single. piston to valve clearence is good....Im stumped
bowtie81
5,008
sarnia, ontario canada
Are you using a vacuum advance? what type of distributor? check your vacuum lines and if your using a hei distributor check the 4 pin module. are you running any msd? if you have a 6al box try taking the rpm chip out.
RatDime
575
Ind
no msd, no vac advance, distib is procomp, but have new accel with super coil going in.
Sounds like it's too advanced to me.
Assuming all wire connections have been checked, firing order is correct, timing is correct, and the only thing you changed was the heads, I would look closely at the exhaust valve springs for a broken spring, weak spring, or something that is causing the valve to stick open or float under load.
RatDime
575
Ind
springs are too much, need lighter, figure it out, just too much pressure
