I have a Holley 4160, 1850S (earlier version with adj. floats), 600 CFM, Vac. Sec. single feed carb. Since it was new it has had an off idle stumble. I have checked, and adjusted the accelerator pump arm, and of course set the float levels, all of which did not correct the problem. I was thinking of trying a size or two bigger squirter (it currently has a 31 squirter), or maybe trying different accelerator pump cams. I have also heard of changing the accelerator pump out for the 50cc version to fix the problem. Anyone have any advice on where to start?
