housing information ???
fastbuick
33
HI. i need help to order new 9 inch ford model M 9 from moser.axle flange to axle flange i need 45 inch that ok.after ineed housing flange to housing flange ??? i dont have the lenght??after i need driver side housing flange to pignion center??? dont have the lenght?? and the same for the passenger side?? i want order wildwood brake disc for the housing 2.36 offset big ford new style bearing . my car chevelle 79 with original offset on the engine and transmission. HOW to
RICHARD THANK FOR YOUR HELP
find the good lenght.
10secBu
4,284
Westminster, MD
Before you order a Moser, you need to check with TRZ about their new housing. If it's only a street car then any housing is fine, but if you are serious about racing, the TRZ housing is the best bolt-in design I've seen and has the most adjustability in terms of instant center, etc.
Mike and Todd at TRZ are great to deal with.
shadychevyowner
782
Numidia Pa
http://autoweldchassis.com/vbi.ivnu
scroll down to high trac 9 (adjustable). Comes with housing control arms and axles. and other couple things. Very adjustable with 4 spots for lowers and 3 for upper.
