I wanna pull the front tires off the ground...
BOB-O
35
North -O- Houston
LS6 Tommy said:
A 2 ton jack should get it there... #-o
Sorry....
LMAO....
I had a feeling some one wood say that....
Malibu355
1,803
La Marque, Texas
Your rear suspension isnt hurting you because I have a bone stock suspension front and rear and I pull one wheel (g-body twist) all the time at the track.Last time out the guy who went with me said it was 4-6 inches up. Are you having traction issues? How close to Houston are you?
BOB-O
35
North -O- Houston
Actually I dont really feel the tires spinning the last time i took it out to to HRP It seemed to hit pretty hard with a 1.71 60 ft. but no wheelie
I'm like 45min north of Houston, in New Caney. I usually go to HMP, its way closer than HRP.
Wow, your pulling a tire with stock suspension. what times are you runnin.
DFWMalibu
999
Dallas,Tx
more than likely its the cut stock coils... doesn't let the front rise...
Chris K.
HarrisonTX
3,332
Burleson TX
I have bone stock suspension. V6 springs up front, and some "trick" springs in the rear.
I only run 8.0 in the 1/8 and can yank the front left a couple inches.
Clutch drop at 3,000 and ET streets... works every time.
Supe
15,116
Charlotte, NC
Put the tallest, lightest springs you can up front, loose front shocks, and a loose converter. Up and away you go.
BOB-O
35
North -O- Houston
I'm gonna have to try the v6 springs or the "trick" springs. Sounds like that will do the trick.
Malibu355
1,803
La Marque, Texas
I'm in the 1.68 ish 60' times. Now I have added airbags but I havent made it out to the track since.
