injection ?
Are any of you guys running the 6.0 with injection but with the msd set up and not the factory computer
blubaldmontess
872
Clarksville, TN
don't believe you can do it like that. I'm running the 6.0l but I've got to run the computer/harness. I believe the only way to run the msd setup is to get teh carb intake as well. Good luck
I beleive you can buy another harness that comes with the msd box to run injection and also eleminates alot of he stuff you dont need like the trans i'm running 350 turbo. instead of 4 o2 sens you use 2 with the msd box and can tune everything else right through he box or lap top
MalibuRacing
3,465
www.maliburacing.com
You can delete a lot of stuff from the factory harness. Then, use a tuning program to remove stuff like the rear O2 sensors, smog controls, etc. Or, do like me and send the factory harness and PCM out to Jesse at Wait4Me Performance and he'll do it all for about $325. Much cheaper than going with the MSD setup (if you already have the factory harness and computer).
