Interchangeability of stock gauges?
79Maliboo
608
Mount Laurel, NJ
My dash looks like this, minus the clock:
http://www.turbobuick.com/forums/attachments/turbo-lounge/56456d1221588559-fbi-law-enforcement-grand-nationals-gnxs-malibu-9c1-12.jpg
Can I put a stock tach in the space where the clock is? Do I need a different circut board or back board?
You should be able to swap he tach in no problem, probably just need to add the power/coil wires.
SLICK78
1,120
La Porte, Tx
check this out
http://www.maliburacing.com/gauge_conversion.html
79loserbluebu
302
Illinois-60491
You will need the tach cluster circuit board assembly. The tach doesn't have wires, it has poles that push into place on the cluster, and the circuits are all non serviceable on the back of the cluster.
79loserbluebu
302
Illinois-60491
On second look, Doober is right. I was thinking of the clusters with nothing in the tach spot.
