keeping straight in the burnout box
Chief11885
144
Kansas
I am wondering what can i do to keep my car straight when i do a burnout. i have a full spool so i have no idea what i need to do to fix it thanks.
Chief11885
144
Kansas
air pressure it the same so it might be the wieght. But is there a way that you can get around that because i have seen guys do burnouts and there car stays straight the whole time.
1980PontiacWagon
686
Northern Virginia
Is it the rear end just swinging out or do you do a rolling burn out and the car just pulls to one side? Also what car is it?
Chief11885
144
Kansas
it is swinging out so the brake might be possible. i have been thinking of getting some after market front calipers. Good point, it is an 81 elcamino
Hitman
1,321
OKC
If they won't sit in the water, usually there's a preload issue that needs addressed.
When you start your burnout, do it like you mean it and get it up on the tire too
gman415
883
Chattanooga
When I've worked the starting line, I've noticed some cars if they cross the water with one tire will do this. (one tire wet, one not wet)
