ls brakes?
prairiehotrodder
1,576
Melfort Saskatchewan Canada
What cars can i use the spindles from to upgrade the brakes on my 81 malibu?
brian
axisg
407
YYZ ( Toronto )
I feel the easiest swap is 2wd blazer front brakes ( 98-03 ).
And 98-03 Fbody rear brakes. I believe the fronts make much more impact than the rears.
We did the fronts on my car in under 2 hours, had lunch then did the rears before supper. Although I had new balljoints and springs so it was literally a spindle swap.
HUGE difference in braking. I took a peek on car-part.com for the spindles any only seen a handful of sets on-line in Canada. Closest to you is a set in Calgary
98-03 F Body Rear brake assemblies $75 side at Southside in Weyburn
prairiehotrodder
1,576
I thought the 98 F-body front brakes would work for me? I found a complete pair with spindles for $150
I believe people have put front brakes on g-body or blazer spindles, but I've never heard of f-body spindles.
prairiehotrodder
1,576
So i bought a pair of the 98+ blazer 2WD spindles with hubs. Do the 98+ camaro rotors and calipers bolt right on?
