LT1 Camaro Brakes?
Hi all. Will the rear disks off of a 94 F-body bolt up to an 8.5" rear?
How about the front brakes, is there any way I could use those on my car? I just bought a wrecked 94 Trans Am for the T56, and I'm trying to figure out what other parts I can use off of it.
Deuce4935
341
Chicago, Il
You can use the front rotors but you will need b-body spindles and calipers. the rear disc are another pain in the a##. The 8.5 requires some cutting of the stock backing plate and then welding the trans-am backing plate onto the 8.5's housing. Check over @ turbobuick.com and you can find some much needed advice and help.
