guys is selling a new pair locally for $250 28x11.5x15...
can those fit under my car with a rolled fender lip?
anyone have any feedback on them?
MISFITmalibu63 said:guys is selling a new pair locally for $250 28x11.5x15...
MISFITmalibu63 said:so should i pick these up?
and do the NEED tubes?
$250 is a great price as long as they are brand new, I would grab them. You don't NEED tubes, but you'll be putting air in your tires everyday or two. I don't run tubes. One of my tires doesn't leak at all, but the other one will go flat overnight. But that's because I have my tires screwed. If you don't screw them, they probably won't leak at all.MISFITmalibu63 said:so should i pick these up?
5-door said:$250 is a great price as long as they are brand new, I would grab them. You don't NEED tubes, but you'll be putting air in your tires everyday or two. I don't run tubes. One of my tires doesn't leak at all, but the other one will go flat overnight. But that's because I have my tires screwed. If you don't screw them, they probably won't leak at all.MISFITmalibu63 said:so should i pick these up?
5-door said:If you don't screw them, they probably won't leak at all.MISFITmalibu63 said:so should i pick these up?
