Do you realy need a main cap removal tool? If not how do you remove them.
B BIGDOGG Amateur Racer Nov 26, 2008 131 0 0 gobles mi Dec 24, 2009 #1 Do you realy need a main cap removal tool? If not how do you remove them.
daschra79 Amateur Racer Nov 16, 2009 100 0 16 St. Louis Area Dec 29, 2009 #2 Two 3/8 extensions will work. Just put them in the space under the cap and between the block and gently pry up.
B brrymnvette Frequent Racer Oct 18, 2004 316 0 0 St Louis, MO Dec 29, 2009 #3 I've never used a tool. Just pliers or like mentioned. Remember these are 6 bolt mains. Two are on the side of the block.
