medium tub
toxicbu
616
romeoville il
im finally doing it, the ladder bars and diagnol link are instaled were taking the body off the frame, so i can run every thing out the way and clean and paint the frame. narow the frame rails and tuck a 13 w tire under it.
cutlass389
684
NC
:shock: Wow. Impressive. Take lots of pics for posterity and share some with us as you go. Someday when I grow up I wanna' be just like you. =D>
COPO 572
1,325
Morrisville, NC 27560
Spring is coming..........giddy up.
toxicbu
616
romeoville il
ill be taking pic and posting as i go.
ya spring is real close, it may not seem close but it's right there,
im towing the frame over to my friends garage tonight , and leving the car where its @ this way i can under coat the body.
gstock8732
756
Jersey
Cool. Was waiting for these pics to surface. U were The only one up at 430am doing this as I was stripping the bodys belly a while back. Can't wait to see the finished product.
On a side note. The compressor works wonderfully. I hadda up the pressure a Little and took off the second regulator to get more of a direct flow of air. Now I csn mash the wizzer to the body as hard as I want. And it cycles on at 125psi to keep up with the wheel. Thanks for helping me bud. Wish yah lots of low ets with the bu.
toxicbu
616
romeoville il
glad the comp worked out for ya, will keep every one posted.
toxicbu
616
romeoville il
dun some more work last nite, we boxed the frame so that it stays tru, to nite im cutting the frame out and then cutting the frame rails in half and re welding them back, i think il be able to tuck a 14.00 slick under it.thats ugly79 cuting the frame supports out,
grizwald
3,300
Ontario, Canada
man, you're a ton braver than i am! i only want to notch my frame but can't muster up the courage to just do it! can't wait to see yours when it's finished!
toxicbu
616
romeoville il
I know how you feel , it's took me five years, now im finally doing it
gstock8732
756
Jersey
Cool man. Making good progress. I'm thinking about doing this myself before I put the body back down on the frame. If u can post up as many Picts of the frame portion as possible. Wanna do it myself. Good luck with it. Is tha u sitting on the rear of the frame ?
