My brake quandry
bustedknuckle
959
St. Louis-Missouri
Ready to button up the brakes and have a couple of questions
What do you think about these parts together?
strange 1.032" master
strange 4 piston front disc's
quick performance, GM, rear single piston disc's on the rear (dont know if their low drag or not)
wilwood adj proportioning valve
stock distribution block
Read somewhere about having to remove the residual valve from the stock distribution block? is this necessary?
couple more quick questions
does this look right?
Rear line is closest to the front of the car and front line is towards the rear of the vehicle like the pic right?
and which line goes where in the distribution block? Ive had the car apart for too long it seems because im having a hard time putting it back together.
only one i know for sure is the left hole goes to the rear brake line.
Thanks guys!
You can't run a stock disc/drum combo valve, period. Get one for a disc/disc setup.
bustedknuckle
959
St. Louis-Missouri
why not? If i were to take the residual valve out of the combo valve then it would no longer be a proportioning valve and use the wilwood adjustable prop valve for proportioning otherwise im proportioning a proportioning valve correct?
There is no residual valve in a combo valve. A combination valve only performs the duties of a metering valve & a proportioning valve. The metering section of a disc/drum combo valve delays the activation of the front brakes to give the rear shoes a head start to contact the drum. If you use a disc/drum combo valve (or a disc/drum metering valve) with rear discs, you get rear lock up. The proportioning section is different, too. A disc/drum combo valve backs off the rear brakes at a much lower rate than a disc/disc valve does. Again, you get too much lockup.
