NEED HELP...
mikethehammer
28
So after cutting my coils to get the right height i took her for a test drive and the transmission is shifting funny and there is a burning smell i can't describe.. i only cut 3/4 of a coil in front an 1 inch drop in the back. could the drive shaft angle be causing my transmission to shift crazy.. this is odd ... also put modifyd crossmember and notice you can lift the transmission and crossmember up an inch or so with your hand, is this right.. need some help boyz
bowtie81
5,008
sarnia, ontario canada
You shouldn't be able to move the transmission and crossmember. I'd get back under there and see what's loose.
mikethehammer
28
thats how it was when i bought it and it drove fine, i check it out.. any idea on the shifting with cut springs?
bowtie81
5,008
This is a shot in the dark but how far is the yoke sitting in the transmission, with it being lowered more could the yoke be sitting in the transmission to far and it's rubbing?
mikethehammer
28
well, i put the original springs back in the rear and it drive alot better. but i am still concerned about the crossmember and transmission play. everything is bolted in seems like the crossmember is rigid enough to hold the transmission, how the hell do i fix that its the original,
bowtie81
5,008
Did you put the rubbers back in where it bolts to each side of the frame?
