Need some 9" info
Hooligans
73
Belfair, WA
Ok, after not finding a 9 inch in any local yards that I was interested in I started to do some digging around to see what I could find.
I have a new 9" housing on its way that is 53" bearing flange to bearing flange, new style big Ford housing ends 3.15 OD bearings, and 3/8's axle retainer bolts. Besides the obvious on needing the G-body brackets, keeping in mind that this will be out back with a BBC, what parts (without breaking the bank) should I be looking into?
468malibu
425
Binghamton NY
Forgot much about 9", but the one that i had in my 'bu when I first got it had 28 splines and a spool. Car that it was in ran the 10s, tho it was only a small block, was running a sh!t ton of nitrous.
I would think a good center and 31 spline axles should be sufficient??
The 9" I got from Drivetrain Direct has "Torino" bearings, Superior ring, pinion & 31 spline axles & an Auburn Pro series diff. They rate the rear at 650 HP...
Hooligans
73
Belfair, WA
Tommy, the one I bought is also running the "Torino" bearings. The next piece on my list is a new center section. Is the nodular fine or should I run with aluminum? Sorry for the dumb questions but this is my first 9"....
TURNA
6,031
Socialist NY
I run a nodular case, 31 spline and a detroit locker.
If you getting a posi unit make sure it is a 4 pinion unit and not a 2 pinion
cbh-7726-80
117
maple ridge,b.c.
when i bought my centre from strange eng.i was going to get the alum unit,but they did not recommend it for a sreet driven car as there is too much gear pattern change due to the expansion of the aluminum,bought the steel unit,been beating on it with a 600 hp big block for 2 seasons,no problem
I don't think mine is nodular & like I said, it's rated for 650 HP. I think it's just standard chunk. Nodular certainly couldn't hurt it's not too much more money.
Hooligans
73
Belfair, WA
Well needless to say, the housing arrived. The problem I have is bearing flange to bearing flange is only 51", not the 53" it was claimed to be.
Now for the questions..... I am trying to decide if I should run a disc rear kit or just run drums. Am I to assume that the disc kit does not add any width? And for wheels, What backspace would I need to run with this width? Trying to tuck the rear a tad with rolled lips. The original add with 2.5" offset axles would be 58" wheel flange to flange. I am going to assume that the new width is going to be 56"
468malibu
425
Binghamton NY
Could run some spacers then a wheel with little more offset to the outside...Also might want to put some braces where the center and tubes come together.
