One more fogger question
NoMoore
1,833
Rochester, Pa
I am going to put new lines on my pro shot fogger, because the existing ones look like poo.
Are there any guidlines for how long the lines can be from the solenoids to the nozzles?
Do they have to be matched in length?
NoMoore
1,833
Rochester, Pa
Alright, you guys need some pictures, so i can get some replies.
Here is what came on the car when I bought it. As you can see, it was bent by hand and looks like poo. It also forces me to run a 9 inch aircleaner, and a cowl hood. But I know it is the most direct way to plumb it.
This is an idea I have. If I were to stuff the solenoids down in the intake, then run braided hose under the intake, coming up and out from the sides. It would be tidy, and easy to change jets. Would it work?
CutlassRacer
5,402
Gainesville, FL
www.facebook.com
We have lines run to the distribution blocks on our BBC Nova that we took to the Pump Gas Drags last year. It is very easy to change jets and the kit hits very soft too. Right now we have about the same HP in the nitrous system as we did with the plate kit so the ET has stayed the same so far, but it hit way softer, which will let us get on the kit sooner into the run.
