part numbers for vette fuel filter/reg for single line
JRodS79
1,567
kansas city mo
wanting to run the one line.
seen them on other projects on here
anyone have a list??
388bu
3,228
Huntley, il
www.shiftn6.com
Just go to Napa, etc and ask for a 2000 corvette fuel filter/regulator. Its about $60 I think.
You will need a 3/8" Russel quick disconnect and a 5/16" quick disconnect. PN 640850 and 640860 respectively.
You will also need a short piece of quick disconnect repair tube to go into the output side and then a hard line to -6 adapter. You can pick the tube up at Napa as well. It will be in the quick disconnect repair section.
Dont forget another #640850 for the fuel rail.
JRodS79
1,567
kansas city mo
thank you sir
Stangboy
833
Ky
I have a filter/reg Im not gonna use, make me an offer......
455_82malibu
1,400
WISCONSIN
those russel fitting are only rated to 50 psi... everybody uses them, not sure why they are rated so low? The only thing I can think is the aluminum body cant compress the inner sleeve as tight as the brass fitings?
quickie70
65
Denver, CO
ok, I'm using this setup, but what did you use to mount the filter? That metal/foam piece looks like a factory setup, and I like it! Also, is the inlet on the same side as the return line or is the outlet on that side?
