pics of new door pins installed
does anyone have close of shots of new pins and bushings installed on their car? im about to get into doing mine just want to see how they look. and best way to do them.
TTT
I'm about to put these in this weekend, just the pins and bushings before i install the front clip and i want to know how they go in. I have heard just take out the old ones and hammer in the new ones, is it that easy??
i'd like to see someone who has installed a set just so i know where the bushings go,e tc
79izfine
2,199
massachusetts
the copper bushings go in top and bottom of hinge tap out pin with hammer then tap out copper bushings then tap in copper bushings ,,, tap pin in .... theres also a tool to compress the spring if need to remove dont know if spring removal is necessary did a set on my 86 camaro years ago fairly simple
4,759
The pins are staked and do not just drive out easily. If you hammer too hard, you distort the hinge and the door will not close properly. Ask me how I know.
You will need to grind/file down the obstructing parts of the pin before trying to drive them out.
got them in, so glad i did it, doors close like new.
just took the door off, and re-aligned it.
