Question about inner tubes....
Malibu 361
1,286
Queens,NY
When do you have too use them?What kinda tires?Why do some tires not need tubes??I want too get a set of Hoosier slick and not sure if I need tubes?
bbc-olds
542
Malin OR
Drag slicks generally have thin side walls and air will leak right out the side. Tires these days don't have that problem much. Run them tubeless unless you have some older wheels(supertricks) that require tubes.
Malibu 361
1,286
Queens,NY
But if I run 28x 10.5 Hoosiers they say I need them ...Robert you say that you don't run tubes??
Robert1320
How quick are you going? The more power you have the more you should stay away from them.
No, I don't run them. You are much more likely to run into tire shake, increased rotating mass, and slow reaction.
You may need to screw, glue or bead lock the tire to keep the tires on. And may have air loss over time.
