Mechanical fuel pump question
tuggy24g
633
Newtown PA
www.buckslp.org
I have an 1986 El Camino with a 402 big block. 750 cfm and a mild engine . It's not a big horsepower machine. Probably around 300-400 HP. I am replacing the mechanical fuel pump and wanted to know if there is really a difference between all these different ones you can get at local auto parts stores.
- Delphi Fuel Pump AMF0068
- Napa B0174P
- Carquest Premium 1542665
4,770
39
If you are going to use the factory hard line to the carburetor, carefully match the new one to the old one. The last new pump I got had the bottom clocked in the wrong position; I had to exchange it for another.
tuggy24g
633
Newtown PA
www.buckslp.org
Other then that is that the only thing to watch for? I did not know if there was a different? The new one I looked at was exactly the same outside
4,770
39
If your car has a return line, you need the pump with 2 inlets and 1 outlet.
Delphi is the source of OEM pumps as far as I know.
Apart from that, get the one that has the best warranty.
tuggy24g
633
Newtown PA
www.buckslp.org
All of the pumps linked above. Are exactly how my setup is
