mechanical fuel pump
79sbcmalibu
152
milford , ct
ok so to start my malibu every morning takes so long i have to pump the gas a bunch of times and keep doing it over and over again till it starts if i got an electric fule pump will this solve my problem and if it will solve my problem wich is a good fuel pump
DOUG213XRJ
4,671
West, MI
Cranking the starter motor for a wile will fill the carb with fuel , Then pump the pedal a few time then it should start and stay running.
Pumping the gas pedal a million times is not going to change no matter what kind of fuel pump you have. You need to get your choke set up properly.
lurchsmalibu
3,774
Lakeland, Florida
What carb do you have?
Is fuel staying in the bowl(s) over a long period of sitting?
+1 with Tommy about the choke. 8)
Electric pumps are nice, but it won't make a good bandaid to cover another issue of hard starting.
grizwald
3,300
Ontario, Canada
79sbcmalibu said:
so what do i do with the choke
i'd get someone who's experienced with them to set it up for you and show you how to do it down the road if needed.
lurchsmalibu
3,774
Lakeland, Florida
+1, chokes can be temperamental when adjusting unless it's manual. Then it's on you for the amount of choke being applied.
This may not be any good as for helping you, but it will give you an idea.
http://www.holley.com/data/Products/Technical/199R7948-5.pdf
If I were local I'd just come by. It's more of a "best guess starting point" thing than an actual set in stone procedure I could quote to you.
79sbcmalibu
152
milford , ct
ok thanks guys i guess im just going to have to learn it on my own my uncle is really good with this kinda stuff i guess i will have to ask him for some help and learn that way
