mechanical fuel pump
barnym17
858
ohio
If your good on fuel injection think of it this way, the choke is your cold start enrichment.Start with the basic setting available for your carb at holley .com then from there a tighter choke means more enrichment longer looser is just the opposite.Tinker with the setting till it does what you need.
80montecarlo
1,123
cloverdale b.c. canada
I never use a choke, it is the first thing eliminated from my carbs when I buy them. The electric fuel pump is nice because you don't need to wait to fill the bowls, hit the switch wait for the sound of the relief valve going off in the pump and give'r. Yeah I have to hold the engine @ 1500 rpm for a minute or two but after that everything is good to go.
79sbcmalibu
152
milford , ct
what fule pump do you use
80montecarlo
1,123
Holley blue, I have them on 3 vehicles and none of them have chokes.
79sbcmalibu
152
milford , ct
will this pump hold up nitrous to because i plan on spraying it also
