radial g body ride height question
rodneypierce
473
Cedar Rapids, IA
Hey guys was wondering if some of you stock suspension radial guys could give me some front and rear ride heights. Just something I can use for mock up. Doesn't have to be exact.
Thanks in advance!!
TRZ Motorsports
362
Orlando, FL
www.trzmotorsports.com
Your ride height should be dictated by your rearend control arm geometry in order to get the radial tire to work. You need the lower control arm in the rear to be between higher at the frame than it is at the housing. How much higher really depends on power level, type of rear housing, rear shocks, etc... But it needs to be higher no matter what. Then just set your front up to be a little lower than the back of the car is.
